Whatsapp Business Trigger not working
I never got this :thinking:
Maybe a new process. Will try to test it again if I have some time tomorrow
that would be great :star_struck:
I also faced this issue. And I got it working with n8n trigger node and meta api v22.0, but failed when meta api v24.0. And I can’t switch back to meta api v22.0, so not sure if this is the key difference. :face_with_spiral_eyes:
I have the same problem. Green credentials, even the outbound node is working but the trigger is not. Did you fixed it? Thanks?
Hi, I'm having the same problem. The workflow works fine, but the message trigger isn't working. In the Meta Test API, the webhook works because my test messages are logged, so I don't know what the problem could be.
i got it working.
you must create a phone no, which you must verify.
with the Whatsapp Test Account it doesn´t work for me
