WhatsApp usernames and BSUIDs: why phone-keyed workflows will start missing contacts
If your WhatsApp workflows look contacts up by phone number, usernames are going to hand you messages where the phone number isn’t there. Meta’s page on business-scoped user IDs (updated 23 Oct 2026, and Meta says the feature is subject to change) explains what arrives instead.
Every messages webhook now carries a business-scoped user ID, the BSUID, in user_id. It’s a country code, a period and up to 128 characters, like US.13491208655302741918. Store the full value as a key next to the phone number rather than instead of it.
The phone number still comes in the webhook if that business number messaged or heard from the user in the last 30 days, or if the user is in Meta’s contact book for your portfolio (only for interactions after the contact book launched). Outside those cases you may only get the BSUID.
Since July 2026 you can reply to a BSUID by putting it in recipient and leaving out to. If you send both, the phone number in to wins. A BSUID only works from numbers in the same business portfolio, so a number from another portfolio fails, including a solution provider’s own number messaging a client’s users. One-tap, zero-tap and copy-code authentication templates can’t go to a BSUID and come back with error 131062.
The ID changes when the user changes phone number. Meta sends a user_changed_user_id system webhook with the previous ID, so if you don’t map old to new, a regular customer quietly turns into a stranger.
I haven’t checked how each n8n node exposes recipient, so there’s no node config here. Meta also doesn’t say whether sends to a BSUID count against messaging limits or price differently, or when usernames reach a given country.
Updating your database architecture to dual-key contacts using both phone numbers and the incoming BSUID will prevent webhook message drops when Meta omits phone numbers. Additionally, handling the user_changed_user_id system webhook ensures recurring customers don’t become unmapped strangers when they update their contact details. Let me know if you need help structuring your n8n sub-workflow to parse and store these new BSUID payloads right here.
