When I use the gemini2.5pro chat model on a self-hosted system, the processing is too heavy and it won’t run
When I use the gemini2.5pro chat model on a self-hosted system, the processing is too heavy and it won’t run.
When using the gemini2.5pro chat model on a self-hosted system, how much memory and CPU does the self-hosted system require?
i think it is a bug with all ai agent cpu is spiking
Would this happen if I have too little memory? What is the minimum memory required?
I tried with 16 cpu, its the same goes 100% for no reason.
Hi, could you share your workflow and what version you are using? I have been using the ai agent with gemini models with no issues.
