Hi n8ners,
Any plans for including changing the system prompt?
Thx
@dRAT3 Hey, we’ve just merged support for System/AI/User messages for Basic LLM chain. It will look like this:
For the Agents, you also have ways to control the prompts via options:
Let me know if that helps!
The PR got merged, and a new Docker image was built. If you pull it again, you should get the latest version.
