"I’m building a Google Task bot where I send a message, and it runs through an AI agent to extract the details. The issue is that the agent returns one single output containing all the information needed for the Google Task node (Title, Due Date, Notes, and Status).
How can I split this single output into four separate outputs so each piece of information goes into the correct field in the Google Task node?
I’m open to other suggestions if there’s a better way to structure this!"
- n8n version:
- Database (default: SQLite):
- Operating system:
