“nodes”: [
“parameters”: {
“options”: {}
“type”: “n8n-nodes-base.splitInBatches”,
“typeVersion”: 3,
“position”: [
768,
144
“name”: “Loop Over Items”,
“id”: “038cb313-5e42-449f-bdd0-cc3547196ac3”
“parameters”: {
“resource”: “speech”,
“voice”: {
“_rl": true,
“value”: “7lu3ze7orhWaNeSPowWx”,
“mode”: “id”
“text”: “={{ $json.content }}”,
“additionalOptions”: {
“outputFormat”: “mp3_44100_128”,
“voiceSettings”: “{\n "stability": 0.5,\n "similarity_boost": 0.75,\n "style": 0,\n "use_speaker_boost": true,\n "speed": 1.1\n}”
“requestOptions”: {}
“type”: “@elevenlabs/n8n-nodes-elevenlabs.elevenLabs”,
“typeVersion”: 1,
“position”: [
1008,
144
“name”: “Generate Audio”,
“id”: “da068333-a1a2-49cd-8f59-0ce527dccf65”,
“alwaysOutputData”: false,
“notesInFlow”: false,
“credentials”: {
“elevenLabsApi”: {
“id”: “9cnPNS9Egm9Q1lmb”,
“name”: “ElevenLabs account”
“parameters”: {
“path”: “db0c9de5-c9ab-4482-b80a-a0d076c3f6e1”,
“formTitle”: “Form”,
“formDescription”: " ",
“formFields”: {
“values”: [
“fieldLabel”: “text”
“fieldLabel”: “image”,
“fieldType”: “file”
“options”: {}
“type”: “n8n-nodes-base.formTrigger”,
“typeVersion”: 2,
“position”: [
-64,
144
“name”: “Text submission with divisions nNUMBER”,
“id”: “c1b87efa-74e8-4c87-8487-6dc7be4fedf0”,
“webhookId”: “db0c9de5-c9ab-4482-b80a-a0d076c3f6e1”
“parameters”: {
“jsCode”: “// Gets the text from the form\nconst rawText = $input.first().json.text;\n\nconst regex = /(n\d+)(.*?)(?=n\d+|$)/gs;\n\nconst blocks = [];\nlet match;\n\nwhile ((match = regex.exec(rawText)) !== null) {\n blocks.push({\n number: match[1],\n content: match[2].trim()\n });\n}\n\nreturn blocks.map(block => ({ json: block }));”
“typeVersion”: 2,
“position”: [
320,
144
“name”: “Text separation into blocks”,
“id”: “22277a9b-a462-4a15-9004-eafbc0bb34f5”
“parameters”: {
“jsCode”: “const items = $input.all();\n\nreturn items.map(item => {\n const text = item.json.content;\n\n const cleaned = text.replace(/[\/\\]/g, ‘’);\n\n item.json.content = cleaned;\n\n return item;\n});”
“typeVersion”: 2,
“position”: [
480,
144
“id”: “c2ff9fae-3727-42e2-948c-055d3c04fc39”,
“name”: “Code in JavaScript”
“parameters”: {
“fileName”: "=/files/youtube/audio_english{{$item(0).$node["Text separation into blocks"].json["number"]}}.mp3”,
“options”: {}
“id”: “fade28f9-9db0-4161-b795-31b8a40f06a1”,
“name”: “Save image1”,
“type”: “n8n-nodes-base.writeBinaryFile”,
“typeVersion”: 1,
“position”: [
1280,
144
“connections”: {
“Loop Over Items”: {
“main”: [
“node”: “Generate Audio”,
“type”: “main”,
“index”: 0
“Generate Audio”: {
“main”: [
“node”: “Save image1”,
“type”: “main”,
“index”: 0
“Text submission with divisions nNUMBER”: {
“main”: [
“node”: “Text separation into blocks”,
“type”: “main”,
“index”: 0
“Text separation into blocks”: {
“main”: [
“node”: “Code in JavaScript”,
“type”: “main”,
“index”: 0
“Code in JavaScript”: {
“main”: [
“node”: “Loop Over Items”,
“type”: “main”,
“index”: 0
“Save image1”: {
“main”: [
“pinData”: {},
“meta”: {
“instanceId”: “842620cf479449a2cd5aeaaaceb0f67e5512a70acd309b0df108bddc73a12684”
- n8n version:
- Database (default: SQLite):
- Operating system:
