Workflow could not be activated due to invalid timezone
I can run my workflow, but when it comes to activating the workflow, there’s a timezone error.
Here is my workflow.
  "nodes": [
      "parameters": {
        "resource": "fileFolder",
        "returnAll": true,
        "filter": {
          "folderId": {
            "__rl": true,
            "value": "1GWzyStu7bchhJu2GzjUn7K-nJvTa-pzQ",
            "mode": "list",
            "cachedResultName": "___Laa-laa",
            "cachedResultUrl": "https://drive.google.com/drive/folders/1GWzyStu7bchhJu2GzjUn7K-nJvTa-pzQ"
        "options": {}
      "type": "n8n-nodes-base.googleDrive",
      "typeVersion": 3,
      "position": [
        1420,
        0
      "id": "c93280ec-3ca1-48ec-9d6f-e5bef8f05265",
      "name": "Google Drive",
      "credentials": {
        "googleDriveOAuth2Api": {
          "id": "ih0wjttDn2AVoFl3",
          "name": "Google Drive Laa-laa"
      "parameters": {
        "mode": "insert",
        "pineconeIndex": {
          "__rl": true,
          "value": "laalaan8n",
          "mode": "list",
          "cachedResultName": "laalaan8n"
        "options": {
          "pineconeNamespace": "Laa-laa_2"
      "type": "@n8n/n8n-nodes-langchain.vectorStorePinecone",
      "typeVersion": 1,
      "position": [
        2000,
        0
      "id": "b79973aa-a2f7-47bc-bac8-deaece454728",
      "name": "Pinecone Vector Store",
      "alwaysOutputData": true,
      "credentials": {
        "pineconeApi": {
          "id": "7wnxt4oJWnMrBWVj",
          "name": "Laalaa PineconeApi "
      "parameters": {
        "options": {}
      "type": "@n8n/n8n-nodes-langchain.embeddingsOpenAi",
      "typeVersion": 1.2,
      "position": [
        1820,
        240
      "id": "1d6a143d-c092-45fe-9235-5264bc0acd1b",
      "name": "Embeddings OpenAI",
      "credentials": {
        "openAiApi": {
          "id": "WNWMUv4ycf6wLDxF",
          "name": "Laalaa n8n"
      "parameters": {
        "dataType": "binary",
        "options": {}
      "type": "@n8n/n8n-nodes-langchain.documentDefaultDataLoader",
      "typeVersion": 1,
      "position": [
        2020,
        240
      "id": "71be06b6-167f-43ba-88bc-6221fa2bcb36",
      "name": "Default Data Loader"
      "parameters": {
        "chunkSize": 500,
        "chunkOverlap": 20,
        "options": {}
      "type": "@n8n/n8n-nodes-langchain.textSplitterRecursiveCharacterTextSplitter",
      "typeVersion": 1,
      "position": [
        2020,
        400
      "id": "f325db99-6bc6-447a-abfb-6ff320d5848c",
      "name": "Recursive Character Text Splitter"
      "parameters": {
        "operation": "download",
        "fileId": {
          "__rl": true,
          "value": "={{ $json.id }}",
          "mode": "id"
        "options": {}
      "typeVersion": 3,
      "position": [
        1620,
        0
      "id": "a80d6b1e-fd80-4457-bc5d-3460df03a690",
      "name": "Google Drive1",
      "credentials": {
      "parameters": {
        "options": {}
      "type": "n8n-nodes-base.splitInBatches",
      "typeVersion": 3,
      "position": [
        1840,
        0
      "id": "56ac01b1-87aa-4302-8000-95671ee0b98c",
      "name": "Loop Over Items"
      "parameters": {
        "pollTimes": {
          "item": [
              "mode": "everyMinute"
        "triggerOn": "specificFolder",
        "folderToWatch": {
          "__rl": true,
          "mode": "list",
        "event": "fileUpdated",
        "options": {}
      "type": "n8n-nodes-base.googleDriveTrigger",
      "typeVersion": 1,
      "position": [
        1220,
        0
      "id": "65e2eccf-ee91-45dc-95e9-d61c0cb186d2",
      "name": "Google Drive Trigger",
      "credentials": {
  "connections": {
    "Google Drive": {
      "main": [
            "node": "Google Drive1",
            "type": "main",
            "index": 0
    "Pinecone Vector Store": {
      "main": [
            "node": "Loop Over Items",
            "type": "main",
            "index": 0
    "Embeddings OpenAI": {
      "ai_embedding": [
            "node": "Pinecone Vector Store",
            "type": "ai_embedding",
            "index": 0
    "Default Data Loader": {
      "ai_document": [
            "type": "ai_document",
            "index": 0
    "Recursive Character Text Splitter": {
      "ai_textSplitter": [
            "node": "Default Data Loader",
            "type": "ai_textSplitter",
            "index": 0
    "Google Drive1": {
      "main": [
            "type": "main",
            "index": 0
    "Loop Over Items": {
      "main": [
            "type": "main",
            "index": 0
    "Google Drive Trigger": {
      "main": [
            "node": "Google Drive",
            "type": "main",
            "index": 0
  "pinData": {},
  "meta": {
    "instanceId": "87904629d0f1ee2c5d1328888f3b16390397d9cc13939f91486af7d14556c46c"
  • n8n version: 1.81.4
  • n8n EXECUTIONS_PROCESS setting (default: own, main): own, main
  • Operating system: ubuntu
Hi @CUBEevo_AD
You probably set the timezone of your n8n server to UTC or something similar, this is not correct so it gives you the error that it is invalid. You will need to set the Timezone to something like Europe/London for example.
If you share your ENV variables we can have a look and be more specific. You can also set it in the workflow settings (top right 3 dots-> settings to open those)
