Hello , In almost every workflow that I try I get an execution completing or data transformation problem. What is the main reason for this and how can I overcome it ?
@Kuti01 Buy a VPS and self host there, or better buy N8N Cloud Pro plan that would help you get things done easily, and learn n8n before copy pasting n8n templates:
And consider learning first before posting random workflow questions.
Hi @Kuti01 , looking at your screenshot the workflow stops after the Remove Duplicates node, the rest never executed. This usually means Remove Duplicates filtered out everything and returned 0 items, so there was nothing left for the next nodes to process.
Click on the Remove Duplicates node and check its output, how many items came out? If it’s 0, check what field it’s using to deduplicate. If it’s deduplicating on a field that’s empty or undefined in your data, it treats everything as a duplicate and removes it all.
