Workflow Execution Problems
Hello , the workflow that I am using does not execute totally it stucks in a particular node and don’t transfer data to the other nodes . Can you give me a step by step solution to fix this problem ?
  • n8n version: 2.12.3
  • Running n8n via (Docker, npm, n8n cloud, desktop app):Docker
Hi @Kuti01 Your question lacks information about the workflow you re referring, consider copy pasting the JSON of your flow.
