Does anyone have a workflow for 2-way integration between Google Calendar and Outlook with Perfex CRM calendar?
Here are the details of my setup:
Version of n8n: 1.58.2
Database used (default: SQLite): Yes
EXECUTIONS_PROCESS setting in n8n (default: self, main): Self
Are you running n8n via Docker?: Yes
OS: Ubuntu docker - self-hosted
Thanks in advance for your help
