I need help with a workflow
I found your article here: https://medium.com/@nchourrout/i-made-an-email-auto-responder-to-conquer-my-writers-block-aa2b91db6741
I am stuck on the Assess if a Message needs a reply, nothing is working, please help. =(
My e-mail is [email protected], I appreciate any help, I have a non-profit and it is hard to keep up with the e-mails.
Thank you so much for your time!
Cynthia Cherise Murphy
n8n
2
- n8n version:
- Database (default: SQLite):
- Operating system:
ria
3
Hi @assuaged
Thanks for posting here and welcome to the community!
Happy to help! Could you please be a bit more specific? Where exactly are you stuck? What’s the error you are getting?
You can share your workflow here by pasting them as JSON in between two block quotes (```
Thanks
system
Closed
4
