Hello, I was navigating to the Executions screen and was surprise to see that one workflow is still running after long hours despite the fact it does not have any infinite loop.
Hi @G-Rom, chances are this workflow is no longer running, but n8n is unable to tell (for example because your n8n instance was restarted or crashed during the execution).
You could simply delete the execution manually from your database to get rid of this entry in the execution list.
I couldn’t find an n8n cloud account under your forum email @G-Rom, but if you drop us an email at [email protected] from your n8n cloud email we’re happy to remove that old execution for you
