Workflow Issue on "if node"
I have an If node (is Q7 answered) which checks for a condition: If you check in the execution- The outcome of this node is true and it should ideally trigger both the subsequent nodes (Fetch cards and clean Q1-Q7 inputs): But for some reason only fetch cards node is getting executed and not the "Clean Q1-Q7 node.
Additionally this workflow was working fine till yesterday and i haven’t made any changes in the workflow: I just tried testing today and it is not working now: Any suggestions?
If the remove the fetch card node and directly connect the output of If node to clean Q1-Q7 node then it gets executed automatically.
It seems only one node is getting executed post an if condition node
Hi @Nishant_pandita
You are creating 2 separate paths here. So you need to use a merge to combine the two again if you want to use both in one execution properly.
