Workflow setting to set an interval for required execution
The idea is:
If a workflow does not get triggered and/or executed in a period,
this should trigger the regular execution error handling of the workflow itself.
The missing part would be under “Workflow settings”,
a new value to hold a required execution period.
(Same as “Timeout Workflow”)
This period could be used to execution the workflow and stop it immediately with an error.
The set-error-handler would handle the rest.
My use case:
I want to get an error when a workflow does not get triggered for a set period (Ex. 6h)
It is currently easy to get notified on error but not if a workflow don’t get triggered.
