Workspace Offline (503) and Connection Issues on n8n Cloud
Hi everyone,
I’ve been facing some issues with my n8n cloud workspace and was hoping to get some help or insight from the community.
Issues Encountered:
I frequently get a “Workspace offline (503)” message saying the workspace is restarting or currently offline.
When it does load, I often see a “Connection lost” warning in the workflow editor, which stops me from running or saving workflows.
The issue has been recurring across multiple days (from 21st October 2025 to 27th October 2025) and browsers.
Impact:
Unable to access workflows consistently.
Scheduled workflows are not executing.
Has anyone else faced similar issues with n8n Cloud recently? Would appreciate any suggestions or if someone from the n8n team could confirm whether there’s any ongoing maintenance or outage.
Thanks in advance!
– Ankit Patil
I’m having the same issue! And it also takes too long to save workflows.
i have the same issue now, any updates from your side ?
Hi Ankit
This requires a support investigation. I have taken ownership of the ticket and sent an initial response.
Having the same issue!
Hi - if you are experiencing the same issue, please raise a ticket with n8n support (email: help@n8n.io) as it will require support investigation.
I have set up a new account and experiencing the same issue.
Please raise a support request for this - you can do so by emailing help@n8n.io
Let me know the workspace name and I’ll also take a look.
Regards,
Jon
