Workspace offline (503)! -- HELP
  • n8n version: 1.55.4
  • Database (default: SQLite): Default
  • n8n EXECUTIONS_PROCESS setting (default: own, main): Default
  • Running n8n via (Docker, npm, n8n cloud, desktop app): n8n Cloud
through a http request
Running Bulk Install and Bulk Dillit workflows on the coda
As the above message was exposed, it went dead.
I did a restart on the admin panel, but the status doesn’t move on from yellow at all.
It needs to be resolved quickly.
Can you help me with how to solve it?
ps. I reported it by e-mail, but nothing has been going on since the answer that it is escalating.
It looks like your n8n Cloud workspace is experiencing a 503 error and is currently restarting. This is typically a temporary issue on n8n’s infrastructure side.
Here’s what you can do:
• Wait a few minutes and try refreshing your browser - workspace restarts usually resolve quickly
• If you’re the workspace owner, click the “Admin Panel” link shown in your screenshot to check for any additional status information
• If the issue persists for more than 30 minutes, contact n8n support through the “contact us” link in the error message
• Check the n8n status page at status.n8n.io for any known service issues
Since you mentioned this happened during bulk operations with Coda workflows, the restart might have been triggered by resource usage. Once it’s back online, consider breaking large bulk operations into smaller batches to prevent future interruptions.
