<Hi community,
My n8n cloud workspace (sunlib.app.n8n.cloud) is completely stuck and returning 503 errors. I cannot access it at all.
What happened: I was testing a workflow that included a Wait node set to 120 seconds. After the workflow ran, the workspace became unresponsive and now shows “In progress” status permanently.
According to n8n support AI, this is likely caused by high memory consumption exceeding my plan’s limits.
Questions:
How can I get my workspace back online?
What is the maximum recommended Wait duration for n8n cloud?
Is there a better alternative to Wait nodes for long delays?
Thank you!!-- n8n Cloud users: If you’re experiencing issues with your cloud instance (e.g., can’t sign in, instance unavailable), please contact support at help@n8n.io →
- n8n version:
- Database (default: SQLite):
- Operating system:
