X (Formerly Twitter), "Something went wrong" when connecting a credential
I am trying to integrate X (Formerly Twitter) node into my workflow.
I have my CLIENT ID and CLIENT SECRET ready from X developer portal.
However, when I click “Connect my account,“ it throws an error.
If I open a developer tool on the above popup,
No workflow needed. Just add any X node.
Any help will be appreciated!
  • n8n version: 1.115.3
  • Running n8n via (Docker, npm, n8n cloud, desktop app): n8n cloud (app.n8n.cloud)
  • Operating system: Windows
Hi WhaSuk, I tried to replicate the problem but in my case the authentication works. Your X.com User authentication settings look right, I used exactly the same.
I didn’t get any error on the twitter.com login page, so it’s a bit odd that you have so many. Can you check on the “Network” tab if there are any requests that have a status code other than 200? This might give some more information on what’s going wrong.
