I am having issues with keeping the Oauth2 connection with Xero which I didn’t a few versions back.
Is this a general issue or just my instance?
I get the below but if I run the https://api.xero.com/connections with the same credentials (not reconnected) I do get the instances I am connected to.
It works re-running the flow after I reconnected the credentials though.
@Jon I know that you have good experience on Xero.
I am using the same credentials for getTenant as I am for createContact. GetTenant get a full response whereas createContact get an expired token message.
It’s really weird and I have no idea why this is happening. Always works if I reconnect, then re-run the failed execution (but only for 30 minutes off course).
I am using the pre-defined Xero oauth which has the scope offline.
