Zoho CRM integration
As there are a lot of different things that can be done with that API could you please tell us what functionality you need exactly that we can be sure that it gets implemented if somebody starts to work on it. Thanks!
I think Zapier has nailed the key functionality for this one:
Triggers:
  • New module entry
  • Updated module entry
  • New/Updated module entry
Actions:
  • Create/Update module entry
  • Create module entry
  • Update module entry
  • Find module entry
  • Add tag
  • Add note
  • Add attachment
  • Convert lead
Module meaning one of their objects (Leads, Contacts, Deals, etc.)
