Zoho CRM node issue
Hi there,
I’ve been trying to build a workflow that includes the Zoho CRM node. The two nodes before it execute successfully, but the workflow fails once it reaches the Zoho CRM node.
I have an active Zoho account and have successfully connected it to n8n — the credentials appear correctly in the Zoho CRM node. However, I’m encountering an error when this node executes.
Please see the attached screenshots of the workflow and the Zoho CRM node issue for reference.
Thank you in advance for your help!
Best,
Andrew
