Adding System message option to question & answer chain ?
When debugging the question & answer chain, I can see a system message is sent containing some instruction plus the result from the vector search.
But instructions are in english, and very simple and I can’t tune the behavior of the AI Agent.
I tried to change the human message with some success and fails. But wouldn’t it be simpler to have the same possibility as in AI Agent to define the system message ?
- n8n version:
- Database (default: SQLite):
- Operating system:
