Connect LMStudio x Basic LLM chain
Hi guys, how to LM studio to n8n Basic LLM chain. There is no option to choose self hosted model. I have found that I can add OpenAI model, and change the URL to my Self Hosted model. But it’s not working. LM studio gives 200 error. I guess it’s due to there is no API key in credentials
I got error 200 on LMStudio side. I guess because I’m using OpenAi node which reqires to add API key, but LMStudio doesn’t require API key.
“meta”: {
“instanceId”: “3f65f6f9fb3cbf10072a7fc8c26aa0afc98ab64931665c6b618072d063390891”
“nodes”: [
“parameters”: {
“public”: true,
“options”: {}
“id”: “8e2e6020-6529-4345-867c-3a2c46ecdfad”,
“name”: “Chat Trigger”,
“type”: “@n8n/n8n-nodes-langchain.chatTrigger”,
“typeVersion”: 1,
“position”: [
420,
420
“webhookId”: “845ae96e-e3f0-4c6c-9429-6bcbb445a974”
“parameters”: {
“prompt”: “Introduce yourself”,
“messages”: {
“messageValues”: [
“message”: “Always answer in rhymes.”
“type”: “HumanMessagePromptTemplate”,
“message”: “=Introduce yourself”
“id”: “a85470d4-cff4-4857-93c4-184b8d2809bb”,
“name”: “Basic LLM Chain”,
“type”: “@n8n/n8n-nodes-langchain.chainLlm”,
“typeVersion”: 1.3,
“position”: [
640,
420
“parameters”: {
“model”: “Mistral-7B-OpenOrca-lora-merged”,
“options”: {
“baseURL”: “https://lmstudio.sergejs34.xyz/v1/chat/completions”
“id”: “69051db9-da5a-4c31-9baa-4d282605f5ca”,
“name”: “OpenAI Chat Model1”,
“type”: “@n8n/n8n-nodes-langchain.lmChatOpenAi”,
“typeVersion”: 1,
“position”: [
640,
620
“credentials”: {
“openAiApi”: {
“id”: “Pfs8xX3ZtOPqOmeq”,
“name”: “not needed”
“connections”: {
“Chat Trigger”: {
“main”: [
“node”: “Basic LLM Chain”,
“type”: “main”,
“index”: 0
“OpenAI Chat Model1”: {
“ai_languageModel”: [
“type”: “ai_languageModel”,
“index”: 0
“pinData”: {}
nothing
  • n8n version: 1.26.0
  • Database (default: SQLite):sqlite
  • n8n EXECUTIONS_PROCESS setting (default: own, main):default
  • Running n8n via (Docker, npm, n8n cloud, desktop app):docker
  • Operating system:ubuntu
Hi there,
I am having a similar issue.Would be great to have the ability to plug in LM Studio.
Thanks for sharing
Any progress with this? Why no response from n8n? It is not too hard to rig a simple connection to LM Studio with HTTP Request, but I as well want to leverage the langchain implementations. Perhaps Langchain Code is a possibility, but it still appears that n8n wants to force its users to their AI partners rather than allow it to be open. Would someone from n8n please respond?
There has been no response from the N8N team. I will install the Ollama self-hosted version, then connect with N8N and post an update here. That will probably happen within two weeks.
I will use this one:
As n8n has native Ollama node it should work.
Cool. Also, this may be of help LM Studio · Issue #9 · langchain-ai/opengpts · GitHub
Hi everyone,
sorry for the late reply. I’ve just tested latest version of LM Studio with n8n and received an output from the model using the OpenAI chat node.
@Ivars_Pavlovich It seems like the problem with your workflow is that you have the BaseURL set-up incorrectly, please check the screenshot above.
Here’s the full workflow although it’s pretty simple one:
