Is it possible to convert an Expression directly in Set node?
Example: {{$node["Hubspot"].json["properties"]["notes_last_updated"]["value"]}} is a timestamp from Hubspot I need converted to ISO Date Time.
Tried several combinations with .toISOString() but it does not work…
@Jakob_Tiebel {{new Date($node["Hubspot"].json["properties"]["notes_last_updated"]["value"]).toISOString()}} Im assuming the notes_last_updated.value is in milliseconds.
Hi @RicardoE105. Many thanks. Not sure if millisec. Damn, forgot the new Date().
But sadly does not work… This is how the value looks like..
What operation are you using in the HubSpot node? So that I can have a proper look.
Hubspot node, get, additional fields, properties, “Last Activity Date” and “Last Modified Date”.
The expression of these two fields i want to convert to ISO Date/ Time in a set node
ahh was not working cuz HubSpot is returning the timestamp as a string and the new Date function needs the timestamp as a number. Basically, the same I suggested before just that now it’s mapping the value from string to an integer.
{{new Date(parseInt($node["Hubspot"].json["properties"]["lastmodifieddate"]["value"])).toISOString()}}
May thanks for checking again. Now it works fine!
