Hey @lcparreira , your aproach does not utiulize the “pagination” feature of HTTP Request node. More over, your implemented logic of pagination does not make much sense to me, specifically the string condition {{ $('Página Atual').item.json.page }} == {{ $('Consulta Produtos').item.json.products.last_page }}. The page on the left side is always equal 1 and the last_page on the right most likely some string value.
As for the stuck If, it is likely a UI glitch. I suspect your workflow gets into endless loop.
The condition {{ $('Página Atual').item.json.page }} == {{ $('Consulta Produtos').item.json.products.last_page }} is comparing the current page (that is incrementing at end of each run when condition fails) to the last_page (info that comes in the http request and tells the last page of request). It should increment page and loop while page < last_page, and halt when page == last_page
Hey @lcparreira , if last_page value ever becomes 1 then yes. By the gist of it, I assumed the last_page is some sort of URL rather than the number. That is why I suggested that the If condition never fulfills.
I would suggest to look into the data returned by Atualiza DB node during the iteration that is held. Looks like there is something in there which might cause IF node to stall.
Could it be that when the execution stops at the ‘if’ node, it has output on the true branch but not on the false branch? In that case, n8n would naturally stop executing because there are no more nodes left.
If that’s the case, you need to connect the true branch back to the beginning of your loop too.
