Help with Execute Workflow in AI Check Meeting Slots Template
Setting up the N8N template for Checking Meeting slots using AI
Im running into an error with the workflow tool attached to the agent - see screenshot. I cant work out how to get the workflow ID into that node?
I think that the workflow execute trigger has to run first to generate the ID but then im not sure how to execute the workflow trigger!
Im sure its my lack of understanding on how the flow hangs together as im fairly new but be very grateful if someone can help me get this working thanks
I see this message in the workflow tool but cant work out how to define the workflow and im assuming its the bottom flow to get all google events?
its the n8n team template thanks
This tool will call the workflow you define below, and look in the last node for the response. The workflow needs to start with an Execute Workflow trigger
  • n8n version: Version 1.37.3
  • Running n8n via (Docker, npm, n8n cloud, desktop app): selfhosted docker
  • **Operating system:**linux
Hi @aidiva :wave:
Can you change the name in the node to Calendar_Availability like this? That should fix this up!
@Jon is already on the case updating the template :raised_hands:
