Problem with Postgresql node and data ingestion
Error message
Hi all I’m trying to populate a table with the postrgesql node. The has been created successfully, and I have a specific column named geom which a geometry column to store a point for mapping;
When I use this query in pgadmin evrything works : INSERT INTO acledgat (geom) VALUES (ST_GeomFromText(‘POINT(12.5 40.2)’));
But when I want to do the same with the postgresql node I have an error (incoming data are stored into a json file)
If someone had an idea … Thx
- n8n version:
- Database (default: SQLite):
- Operating system:
