Node output sorting reversed with 'use error output'
On a mySQL node, when using the ‘Continue (using error output)’ on error type, the results are reverse sorted. For ‘Continue’ or ‘Stop Workflow’ the results are sorted correctly.
N/A
Note, the sequence command may be MariaDB only, but just produces 5 sequentially numbered rows. The same happens for real queries with an ORDER BY clause.
“seq”: 5
“seq”: 4
“seq”: 3
“seq”: 2
“seq”: 1
  • n8n version: 1.63.4
  • Operating system: Linux
Looks like it’s not just mySQL nodes - the same happens on a code node:
@Jon @netroy FYI
Hi guys, thanks for reporting this!
Will create a ticket to get this looked at :eyes:
Thanks! :slight_smile:
New version [email protected] got released which includes the GitHub PR 11684.
