Greetings,
I wanted to share that I created a custom Node to automate my actions in Raindrop and perform backups. I used the template provided by n8n, which you can find here: GitHub - n8n-io/n8n-nodes-starter: Example starter module for custom n8n nodes..
Unfortunately, when modifying it and publishing it to npm, I ran into an error that I’m trying to fix. Here is a screenshot of the error: n8n-node - Album on Imgur.
When I run the node locally, following the instructions detailed in the official documentation here: Tutorial: Build a programmatic-style node | n8n Docs, the node works, but in test mode. Here is a screenshot of what it looks like: local test node - Album on Imgur.
Here is the published npm node n8n-nodes-raindropbackup - npm
I use Windows 10 as OS in addition to Ubuntu and I get the same local error in test mode I can see the node but once I publish it I don’t.
I would greatly appreciate any help or suggestions to fix this problem and get my node in a fully functional state. thanks in advance for your help!
- n8n version:
- Database (default: SQLite):
- **Operating system: Ubuntu and Windows 10
