Problem with import all workflows
I have a folder with 1 workflow, when I import a specific file I wrap the JSON with and its work fine, after that I removed the , and try to import all jsons in a folder and it’s not working
Hi @Asaf_Shay, this sounds like a follow up to Can't see any change after i import workflow from file - #5 by MutedJam. Since that topic is still unsolved it’d be super helpful if you could ask your follow-up questions in there.
Thank you!
