Accidently Deleted workflow recovery - N8N hosted
Hi,
I was in the mist of cleaning up my dashboard by deleting unused workflows.
Because of the slow dashboard refresh times, I seem to have selected and deleted an active workflow that I did not intend to.
How do I recover the workflow? We are not running a backup system, however we are hosted by n8n.
Thank you!
Weee
Did you reach out to support? Assuming that you are using n8n cloud, they should be able to get your workflow(s) from backups.
Yes, thanks for the response.
we are using n8n cloud.
How do I reach out to support?
Hi @weee , email us at [email protected] from the registered email address.
One of the best practices since n8n introduced the new folders feature is to create a folder named ‘Archive’ When you decide to delete a workflow, simply move it there instead.
