Add a condition for IF node execution
HI Team,
I have a use case where I want add a condition on the execution of IF node.
Example,
If the IF node false execution is ZERO then I want to execution something.
How I can check the execution of IF node.
Thanks
NO
  • n8n version: 1.51.0
  • Database (default: SQLite): POSTGRESQL
  • Operating system: MAC
Hey @Gouravdev,
When you say the execution is Zero do you mean if it doesn’t run or if the output is zero?
