In parameters for If node have Always Output Data, but it works only for true statement. But the idea is to add a switch that will Output Data by users choice: Output Data from both statement, Output Data from true statement, Output Data from false statement.
My use case:
It helps me with data collection when I create no existing folders/files/databases.
unfortunately don’t know how code with TypeScript and I have very bad knowledge about JavaScript. Also have no time for it…
Currently, its a hazzle. I can only design the logic flow in the branch that has data, then I need to go back and load wrong data so that I can work on the logic of hte false branch. It makes no sense. Also the false branch should allow me to retrieve all prior data.
