Add IMAP custom Rules with subject and body email contain of text
Hi all,
[“UNSEEN”, [“SUBJECT”, “Attention - Tbssvr-wmdash0234”],[“Body”,“Partition of Drive”]] i can get data from email for may rules,
thank
Iwan
Hi Iwan :wave: Welcome to the community :tada:
I’m not too sure what exactly you’re asking here, exactly - are you looking for how to filter by label in the IMAP trigger node?
If so, you can add the filter under the “options” section, like this:
If this doesn’t help, could you share an example workflow and go into a little bit more detail about what you’re trying to do? Also, could you fill out this template:
HI EmeraldHerald,
thank you for your feedback, i have rules [“UNSEEN”, [“SUBJECT”, “Attention - Tbssvr-wmdash0234”] it’s filter email by subject, and then i want add filter by subject too, there is any idea to do that filter i have try that one [“UNSEEN”, [“SUBJECT”, “Attention - Tbssvr-wmdash0234”],[“Body”,“Partition of Drive”]] the body is not filter.
regards
Iwan
Hi @Iwan_Yudhistira :wave: I tested this out like this:
And have had no issues with testing and getting emails marked as read :thinking: Can you let us know what version of n8n you’re using? If you’re on an older version, you may be missing some bug fixes.
If you’re on a more recent version of n8n, this can unfortunately also be a potential issue with your IMAP server, which may have different identifiers for messages than you expect. :see_no_evil:
Hi @EmeraldHerald
ehm, for those rules run well, can you add body email for those rules cause i made one before not run [“UNSEEN”, [“SUBJECT”, “Attention - Tbssvr-wmdash0234”],[“Body”,“Partition of Drive”]] and then i run in n8n Version 0.227.1.
once again after i add imap rules [“UNSEEN”, [“SUBJECT”, “Attention - Tbssvr-wmdash0234”], another imap trigger has error, my imap run so well, there is bug, so i upgrade the latest version?
regards
Iwan
I managed to get this to work with ["UNSEEN", ["SUBJECT", "foo"], ["TEXT", "bar"]] - can you try TEXT instead of BODY and see if that picks this up instead?
Hi @EmeraldHerald
i have try your rules, it’s same not work, text not get data off email body, thank you for your feedback
iwan
Hey @Iwan_Yudhistira,
That is interesting it looks like TEXT or BODY should work, Can you share the exact rule you are using?
Hi @Jon and @EmeraldHerald
thank for discussion, i think i found this resolution i’ll try rules [“UNSEEN”, [ “OR”, [“SUBJECT”, “Attention”],[“TEXT”,“Partition”]]]
and then change config with
the rules work well, maybe will be monitored.
thank
Iwan
