Hello
I try to add a very simple (transformation) node to n8n. For this, i have tried to follow his tutorial:
https://support.dropsolid.io/integrations/n8n/extending_with_custom_n8n_nodes/
I have read that with this tool it should be possible to compile just one file and place it inside a folder called “custom” within n8n. This is the approach i try to follow, since my production n8n is running using docker and docker-compose.yml. I would like to expose the cusom folder to the host and just place my single file in there to have my custom node available.
I do the following:
n8n-node-dev new
n8n-node-dev build
I got this error message:
n8n-node-dev build
Build credentials and nodes
GOT ERROR: "Cannot find module 'n8n-node-dev/src'
- Running n8n via (Docker, npm, n8n cloud, desktop app): npm
- Operating system: Windows 10
- Node Version: v 18.18.2
- NPM: v 10.2.0
- Global installed Modules (npm list -g):
±- [email protected]
`-- [email protected]
Thanks for your help
