Advanced Course (1/8) - Working with complex data flows
This video is part of the n8n advanced course. See all 8 videos of this course here.
This was a really helpful overview of data flows in n8n, especially breaking down the node execution order!
Also the Merge node cleared up some confusion I’ve had about it,
thanks🙏🏻
Ola excelente aula.
However, I tried to reproduce the flow but it is not working, I even could not understand where the distinction is made so that the flow understands: hotmail will be personal and gmail professional or vice versa. The only thing is the IF
I think it’s the same as the course
Then the TAGs
Which are completely identical…
I would appreciate any help and explanation on this issue.
None of these videos will open.
That must be a problem on your end - they work fine here.
thanks, this was very helpful
I did not understand why you are using ‘website’ and ‘domain’. Why not the matching key called ‘Company’ ?
