AI Agent - chat history error on using sessionId from previous node
Issue in a workflow with AI agent and agent memory.
What am I doing wrong?
connect “Postgres Chat Memory” to “set_params” (same happens with simple memory)
  • n8n version: 1.9.2
  • Database (default: SQLite): postgresql
  • n8n EXECUTIONS_PROCESS setting (default: own, main): queue
  • Running n8n via (Docker, npm, n8n cloud, desktop app): kubernetes → docker
Hi @ypyly
I was able to replicate the error and found that you’re using an old legacy expression syntax: $node["Node Name"]
Please switch to the current standard syntax $("<node-name>").item which is working as expected:
So in your case, for the Postgres Chat Memory key, try updating your syntax to:
{{ $('set_params').item.json.sessionId }}
Also, since other nodes in your workflow are still using the legacy syntax, I recommend updating those as well to avoid similar errors in the future.
If you find this helpful, kindly mark the reply as the solution :white_check_mark::pray:t2:
oh wow, I didn’t knew that I’ve been using an old legacy expression :slight_smile:
Thanks for mentioning it. Works as expected.
P.S> yeah, went over all of my workflows removing usage obsolete way of referring nodes.
