AI Agent Error with Gemini Model Tools
Hi!
I’ve got this error when trying to use the Gemini Chat Model with tools in the AI Agent:
[GoogleGenerativeAI Error]: Error fetching from https://generativelanguage.googleapis.com/v1beta/models/gemini-1.5-pro:streamGenerateContent?alt=sse: [400 Bad Request] * GenerateContentRequest.tools[0].function_declarations[0].parameters.properties: should be non-empty for OBJECT type
It only occurrs when using Gemini models (with OpenAI model it doesn’t occurrs)
  • n8n version: 1.71.3
  • n8n EXECUTIONS_PROCESS setting (default: own, main): Own
  • Operating system: Ubuntu
Hey @Allan_Montero,
I ran into the same issue with Gemini models—first request works fine, but the second fails. Seems like v1beta is a bit unstable.
I also got a 404 Not Found error when trying to use text-bison-001 with v1beta. Looks like some models aren’t supported for generateContent. You might want to call ListModels to check what’s actually available.
A few things to try:
:white_check_mark: Check API Credentials – Make sure they’re valid in n8n.
:white_check_mark: Try a Different Model – Some versions seem more reliable than others.
Switching models and switching back worked for me as a quick fix. Let me know if you figure out a better solution! :rocket:
