Getting this whenever trying to use o1 on AI Agent:
Unsupported value: 'stream' does not support true with this model. Supported values are: false.
- n8n version: 1.73.1
- Database (default: SQLite): Postgres
yep - please fix that, or at least let us set streaming true or false
just ran into the same, got here searching for a solution. Please fix.
It works on the OpenAI chat with model node btw, just not with agents
I face the same issue as well But in the cloud instance. Is there a planned
fix or workaround available?
ria
7
Hi guys, can you share a minimal workflow to reproduce? So far I haven’t been able to recreate the error
Thanks!
This is fixed in the latest version of n8n (tested on 1.77.0)
