AI Agent problem
Hey,
I’m trying to use AI agents in my workflows, and till a few days ago, I could easily import templates on my self-hosted n8n. But now I don’t see the AI agent input options. At first, I thought it might be a version issue, so I rolled back versions and tried different backups.
Here’s what’s happening in practice, for example, this template:
When pasted into my workflow turns into this:
Even a simple AI agent has the same problem, it used to have different options, such as memory, model and tools:
What do you suggest I do?
  • n8n version: 1.91.1
  • Database: PostgreSQL (via Docker)
  • n8n EXECUTIONS_PROCESS setting (default: own, main): queue (using EXECUTIONS_MODE=queue)
  • Operating system: Linux (Ubuntu)
I have the same problem with my hosted n8n version : ai agent, switch, or text classifier has no branches (if or loop has no problem)
I have tried on different version : 1.91.1, 1.90.0, 1.89.2 , 1.86.0 , with chrome or edge without success
  • n8nVersion: 1.90.2
  • nodeJsVersion: 20.19.0
  • database: postgres
  • executionMode: regular
  • concurrency: -1
  • license: enterprise (production)
  • userAgent: mozilla/5.0 (windows nt 10.0; win64; x64) applewebkit/537.36 (khtml, like gecko) chrome/135.0.0.0 safari/537.36
  • userAgent: mozilla/5.0 (windows nt 10.0; win64; x64) applewebkit/537.36 (khtml, like gecko) chrome/136.0.0.0 safari/537.36 edg/136.0.0.0
Same here. I have daily backups, and I reverted to a few days ago, and nothing. I used different versions of n8n and nothing. I tried starting fresh, and still nothing. I disabled caching on Caddy file, different browsers and incognito mode and still nothing.
The issue appears to stem from using Nginx to reach n8n.
After exposing port 5678 in the Docker setup and connecting to n8n directly on that port, everything works:
n8n:
  ports:
    - "5678:5678"
Now I need to investigate further to figure out what’s preventing access when Nginx sits in front.
Thanks, amazing debugging.
I’m using Caddy, I commented out this line in my Caddy header and that fixed the problem: # Content-Security-Policy “default-src ‘self’; script-src ‘self’ ‘unsafe-inline’; style-src ‘self’ ‘unsafe-inline’; img-src ‘self’ data:; connect-src ‘self’ ws: wss:;”
