Hi n8n team!
I’m on n8n Cloud (version 1.119.1) under the Starter plan.
My workspace URL is: https://trudsourced.app.n8n.cloud
My plan includes 50 AI Workflow Builder credits per month,
but I don’t see the AI Workflow Builder option in my dashboard.
When I visit https://trudsourced.app.n8n.cloud/ai-workflow-builder, I get a 404 error.
Could you please enable the AI Workflow Builder feature for my workspace?
Thanks a lot!
Hi Louis! It looks like you might need to access the AI Workflow Builder through the correct interface. Since you’re on n8n Cloud Starter plan with AI Workflow Builder credits, try accessing it directly from within your n8n workspace by clicking the “+” button to create a new workflow - you should see an AI Workflow Builder option there, or look for an AI assistant icon in your workflow editor.
If you still don’t see the AI Workflow Builder option in your workspace interface, this might be a feature rollout issue. I’d recommend reaching out to n8n support directly through your Cloud dashboard or the [n8n community forum](http://community.n8n.io) with your workspace details, as they can verify your plan features and enable access if needed.
The direct URL `/ai-workflow-builder` isn’t the typical way to access this feature - it’s usually integrated into the workflow creation process within your workspace.
