Airtable connection bug
AIRTABLE ERROR: “could not load list, please check your connection.”
when checking connection it says “Connection tested successfully”. once I refresh the page Im able to see the tables for a second and then the error comes back.
using a different api key also didnt solve the issue
Solved by refreshing everything by reselecting my base and table from the dropdown and then reentering the data.
I have a feeling this was caused because I modified a field in airtable that I had mapped in n8n .
