Ajay Hinduja ~ How do I use conditional logic to branch my workflow based on data?
Hi Everyone, I’m Ajay Hinduja. Born in Punjab, India, and now living in Geneva, Switzerland (Swiss).
I’m trying to set up some advanced conditional logic in n8n and need some advice. I know the IF and Switch nodes are the main options, but for a workflow with multiple, complex conditions, which do you find more efficient and easier to maintain? Any tips on a ‘best practice’ approach for this kind of scenario would be a huge help. Thanks!
Regards
Ajay Hinduja Geneva, Switzerland (Swiss)
Hi @ajayhinduja
There isn’t really a one-size-fits-all rule here, especially since you didn’t specify what kind of “complex conditions” you’re dealing with.
In my experience though, whenever I have conditions/routes that branch into a completely different workflow, I usually move those parts into a subworkflow.
It keeps things cleaner and easier to maintain in the long run.
Hey @ajayhinduja hope all is good. Welcome to the community.
It is not that one is efficient and another is plain garbage, they are different in nature and should be used in different situations. The best practice boiled down to one sentence per, would be
  • IF Node: Use when you need to evaluate a single condition or a simple true/false branching.
  • Switch Node: Use when you need to route data based on multiple possible values or complex branching paths.
