I am trying to auto add “Error workflow” to those were missing that. May I know if any issue with this workflow? When I run this, I can see the Output of the “Update N8N” node will add these 2:
availableInMCP:false
callerPolicy:workflowsFromSameOwner
I find that some sample workflow deliberately remove “callerPolicy:workflowsFromSameOwner”. Is it by any meaning?
Yes, that’s probably because these fields are now added in the newer versions for new features..
You can ignore them since you’re only adding/editing the error workflow ID workflow.settings.errorWorkflow
