Anybody using Hostinger?
guys I’m following a course on Udemy. They use Hostinger as a hosting platform. Has any of you been using it as well?
I have just subscribed but can’t get the setup finished. the app is unresponsive when I click on Setup button. Is Hostinger even trustworthy?
When I go to VPS tab it required my to buy KVM although I’m already subscribed… This is very frustrating.
Hey @bestbubbledev !
If your Udemy course had you subscribe to a Shared Hosting or Cloud Hosting plan (which are very common for courses), you will not have access to a VPS instance.
I think you are confused…
About this, yea used it one decade ago, when I was affiliated(and made some tutorials)… but regularlyI use decent VPS :slight_smile:
Cheers!
Turns out I’ve purchased regular web hosting. Got refunded and re-purchased proper VPS KVM.
Why Hostinger not decent? I was thinking others would be harder to use? Would love to play with Google or AWS but their infrastructure kinda scare me a LOT :thinking:
Yep… as I assumed.
Most “issues” or compications on this forum when ias about the DNS/VPS the word “Hostjnger” is there lol…(is good for the price, 26$ or so, for 8GB and you can use that 8GB constantly 24/7)…
Aws is a bit different(and not hard as you think, once mastered the basics of an EC2 , all other VPS over the CLI is just… fun!), more expensive but I have some others things that leverage some of the work if you know that your app will scale.
And the price it uses “credits” , and if your instance is not on(my use case outbound calls batches 2h /day), I pay for service, so credits are accumulating and I can use them as “extra” if there is spike in resources consumption, and not paying extra resources… is tricky the monetization system indeed :wink:.
They have as well dashboard, or CLi.
Cheers!!!
Hi @bestbubbledev
Hostinger is definitely trustworthy and very popular, but their UI can be a bit confusing for beginners. Here are a few things to check that should solve your frustration:
  • Unresponsive ‘Setup’ Button: This is usually a browser cache issue or an ad-blocker interfering with their panel. Try opening the Hostinger dashboard in an Incognito/Private window or try a different browser (like Edge or Firefox). This almost always fixes the ‘unresponsive button’ problem.
  • VPS vs. Web Hosting (The KVM issue): Check your invoice. Most people accidentally buy ‘Premium/Business Web Hosting’ (Shared Hosting) which is for websites. For n8n, you specifically need a VPS (KVM) .
    • If you bought ‘Web Hosting’, it won’t show up in the VPS tab.
    • If you did buy a VPS, you must complete the initial ‘Setup’ (choosing an OS like Ubuntu) before the KVM becomes active.
  • Udemy Course Context: Most courses recommend using Ubuntu 22.04 or 24.04 on a VPS to run n8n via Docker. If you accidentally bought Shared Hosting, you might want to ask Hostinger support to ‘upgrade’ or ‘migrate’ that credit to a VPS plan instead.
Don’t worry, once you get past this initial setup, Hostinger is actually quite stable for running n8n!
If this answer was helpful for you, please mark it as the solution and give it a like!
