How can I build a scalable web scraping automation using n8n? Any tools or templates?
I use google maps, phantom buster, apollo. These tools really help with web scraping.
I can also help you build one you can contact me at discord: basit.q
Moreover you can find best templates here:
https://n8nworkflows.xyz/
Yes! You can build a really efficient and scalable web scraping workflow using n8n + Firecrawl ā all without code.
I found this awesome step-by-step guide that shows exactly how to do it: Check out this
Hi @kaushik, welcome too community!!!
Anyway, there was soooo many about web scraping in official n8n website!
You can check it here!
Discover 3323 Automation Workflows from the n8nās Community
The Apify store has a pre-built scraper for almost any popular sites. And you can use the Apify node to start the scrape from n8n and collect the results.
