I am running a locally hosted instance. I downloaded n8n yesterday, so I am on current version.
I am trying to install the Apify integration. I clicked on the + searched for Apify, but when I click on install I get the following error:
Error installing new package
Error loading package “@apify/n8n-nodes-apify” :Checksum verification failed Cause: Checksum verification failed. Package integrity does not match.
There are no other nodes in the workflow, I am simply trying to get Apify installed. Any help would be appreciated.
Hi there, you can try installing it from the settings → Community Nodes → Click Install → paste the full name of the community nodes, such as “@apify/n8n-nodes-apify” → check the i understand button → click install
And when you go back to your workflow and search for apify, it should be there and ready to be added
Its better to install it there
Because if you install it straightly from the node panel, some will fail if it’s not a verified community node
If it andwers your question please mark it as the solution and give it a like
Thanks for the info, but after digging in to the apify site, I found that the plugin won’t actually do for me what I need, so I won’t be installing it after all.
