Apparent issue with postgres
  • **n8n version:1.72.1
  • **Database (default: SQLite):SQLite
  • **n8n EXECUTIONS_PROCESS setting (default: own, main):N/A
  • **Running n8n via (Docker, npm, n8n cloud, desktop app):Docker compose
  • **Operating system:Ubuntu 22.04
I’m somewhat new to n8n but I do have a few years’ experience of managing and maintaining docker containers on my home server.
I attempted to install n8n (docker-compose) a few days but kept getting errors that seemed to be postgres related.
Therefore, I completed an installation without the postgres and redis components (using the default SQLite database) and that seemed to work very well: I completed your level one course.
N-8-n is currently running on SQLite however, I understand that postgres is preferred (if at all possible) I’ve re-attempted to get postgres installed but this error keeps coming up:
PostgreSQL Database directory appears to contain a database; Skipping initialization
2024-12-25 16:07:46.455 UTC [1] LOG: starting PostgreSQL 16.6 (Debian 16.6-1.pgdg120+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14) 12.2.0, 64-bit
2024-12-25 16:07:46.455 UTC [1] LOG: listening on IPv4 address “0.0.0.0”, port 5432
2024-12-25 16:07:46.455 UTC [1] LOG: listening on IPv6 address “::”, port 5432
2024-12-25 16:07:46.458 UTC [1] LOG: listening on Unix socket “/var/run/postgresql/.s.PGSQL.5432”
2024-12-25 16:07:46.463 UTC [29] LOG: database system was shut down at 2024-12-25 16:07:45 UTC
2024-12-25 16:07:46.468 UTC [1] LOG: database system is ready to accept connections
2024-12-25 16:07:51.503 UTC [40] FATAL: role “postgres” does not exist
2024-12-25 16:07:56.583 UTC [48] FATAL: role “postgres” does not exist
2024-12-25 16:08:01.688 UTC [56] FATAL: role “postgres” does not exist
I keep getting a 403 error (on this website) when attempting to post the relevant sections from my docker compose…I guess it’s because my account is new.
The relevant sections can be found below:
https://controlc.com/9fae1ca5
Welcome to the community @oneMore !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
I wonder if what you expirience is addressed in https://medium.com/@chunkang.wong94/how-to-fix-the-role-postgres-does-not-exist-error-when-deploying-postgresql-docker-container-430e903b97fd.
Hello,
Thanks for the welcome and the response.
I did read that before and ran the commands advised but I don’t think that’s the solution for me.
Please see below:
onemore@uhts:~/docker$ sudo lsof -i :5433
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
docker-pr 2963707 root 4u IPv4 34733985 0t0 TCP *:5433 (LISTEN)
docker-pr 2963718 root 4u IPv6 34739861 0t0 TCP *:5433 (LISTEN)
onemore@uhts:~/docker$ sudo lsof -i :5432
docker-pr 638411 root 4u IPv4 26231160 0t0 TCP *:postgresql (LISTEN)
docker-pr 638420 root 4u IPv6 26232754 0t0 TCP *:postgresql (LISTEN)
onemore@uhts:~/docker$ sudo lsof -i :444
docker-pr 5164 root 4u IPv4 22883 0t0 TCP *:snpp (LISTEN)
docker-pr 5182 root 4u IPv6 20329 0t0 TCP *:snpp (LISTEN)
While this wasn’t exactly the solution, it got me thinking.
I’ve now managed to get it to behave.
Changes in bold below:
  #n8n Postgres - Postgres database for n8n
  n8n_postgres:
    image: postgres:16
    container_name: n8n_postgres
    hostname: n8n_postgres
    restart: always
    environment:
      - POSTGRES_USER=${N8N_POSTGRES_USER}
      - POSTGRES_PASSWORD=${N8N_POSTGRES_PASSWORD}
      - POSTGRES_DB=${N8N_POSTGRES_DB}
      - POSTGRES_NON_ROOT_USER=${N8N_POSTGRES_NON_ROOT_USER}
      - POSTGRES_NON_ROOT_PASSWORD=${N8N_POSTGRES_NON_ROOT_PASSWORD}
      **- PGPORT=5433**
    ports:
      - "**5433:5433**"
    volumes:
      - $DOCKERDIR/appdata/n8n_postgres/db_storage:/var/lib/postgresql/data
      - ./init-data.sh:/docker-entrypoint-initdb.d/init-data.sh
    healthcheck:
      test: ['CMD-SHELL', 'pg_isready -h localhost -U ${N8N_POSTGRES_USER} -d ${N8N_POSTGRES_DB}']
      interval: 5s
      timeout: 5s
      retries: 10
Thanks for sharing. I have reformatted your post to make your updates better visible.
