Append option does not appear on my airtable actions
Hi I cannot find the ‘‘append’’ action for Airtable on n8n
I want to use append actions to send the HTTP request data to Airtable
Hey @Youssef_Enjri,
The course is currently being updated but the option you would need in the newer node versions is Create which will do the same thing.
hi @Jon,
I would like to thank you for your response.
Actually I don’t know why when I use the “Create” option on the course I have an output that is like this and I dont need actually a lot of colomn like ID and Createdtime clomn also the output that I actually need is all stacked in one colomn.
Any insights ? thank you
Hey @Youssef_Enjri,
That looks right to me, using that output you can still complete the course. Out of interest which course are you making your way though?
