I can’t figure out how to connect n8n with out auth0 app.
Auth0 expects the request to be in this format:
curl --request POST \
--url 'https://predium-staging.eu.auth0.com/oauth/token' \
--header 'content-type: application/x-www-form-urlencoded' \
--data grant_type=client_credentials \
--data client_id=YOUR_CLIENT_ID \
--data client_secret=YOUR_CLIENT_SECRET \
--data audience=YOUR_API_IDENTIFIER
however for the sake of it i could not make n8n send a request of that schema. I only have the possibility to set “scope” in the OAuth 2 API credential setup screen which results in a body param of the form:
scope=audience%3Ahttps%3A%2F%2F<our_site>.eu.auth0.com%2Fapi%2Fv2%2F&
but i need audience=…
Has anybody successfully connected n8n with a auth0 m2m app? (not management api)
I feel like this is due to limited customizability of the credentials?
Thanks for any help!!
varying but mostly: Unable to sign without access token
- **n8n version:1.69.2
- **Database (default: SQLite):default cloud
- **Running n8n via (Docker, npm, n8n cloud, desktop app):cloud
- **Operating system:MacOS
